1 - 15 of 15 Posts
Ok guys please don't answer me with "use the search button" I know this is probably the most talked about topic on this forum but I couldn't just find an exact clear answer. Hopefully you guys can help me out. I have my eye on the Dunlop 250-40-18 rear tire. I know this tire will do fine without any mods, now the question is: my wife really wants to ride with me, but I don't know if the rear fender will hit the tire on bumps with both on top(360lbs total). Of course considering I have the stock suspension spring. Thanx guys for helping out on this...
_M_ said:
Your good. That's the tire I run with the PCS lowering links. By myself 190 lbs) it's perfect. With passenger I flip it on the 1" setting and have never bottomed out. With stock suspension, you'll be golden.
Thanx "M" you rock my brother. I'm ordering my new tire tonight. I found it on amazon for $168.00 shipped which I think that's hella-good no? Still can't believe my almost brand new tire went to sh^*+ for a simple nail. God!!!!! Once again thanx for the relief bro :)
Would that still hold true with the PCS links and their Progressive Spring package? I want to get the PCS lowering package, and I'm eyeing the Avon 240. I've been concerned not only about bottoming out, but dragging my foot pegs.
Oh your gonna find your pegs scraping sooner or later my friend even if you leave it completely stock. ;D.
You lower it 2.25 you will drag your tailpipe and even grind the exhaust pipe mount right at the same time or before hitting the peg if you hit a dip in a steep turn at speed riding solo with a 240 on it, without bottoming out the tire. I've done this several times and I weigh less than 150lbs.
It only bottoms out the tire with 400+ lbs of combined total weight when I hit some pretty hard bumps or potholes. One time in San Diego on the freeway it bottomed out/rubbed slightly going over a bridge with dips in it at 75 mph with 425+ lbs on it . My pre-load set at #7, links at 2.25, 240 Metz and no progressive spring.
The biggest problem is at slow speeds with a full load 2 up if I hit serious dips or speed bumps it hits the rub indicators which are two tabs that come to a point and they gouged my tire.
Straightjacket posted pics that shows where those tabs are under the fender. You should grind those flat so this doesn't happen to you should you chose the 2.25 drop and come across a big enough dip to cause you to bottom out.
Don't be overly concerned though because the circumstances that it took for these things to happen to me are on the extreme side of things, with exception to the freeway in San Diego. The mountains where I live have really bad roads with steep grades and sharp turns and I was ridding very aggressive.
Other guys have the same set up or even larger tire and very few of them speak of hitting the tailpipe or mount in right hand turns.
bivboys3 said:
Hi Straightjacket, could you possibly repost the pictures of the rub indicators or tell me were I can find them on the forum.
Thanks.
If you want to, click on the "members" above, you will see a list alphabetically. goto page 49, towards the bottom. Click on Straightjacket, click on "view all images", the pic you are looking for is in the 2nd row, 3rd pic from the left. They are under the rear fender above the rear tire.
bivboys3 said:
Thank you Wyntress. I followed your directions and found the pic.
Straightjacket thank you for pointing out the rub indicators in the first place. I never realized that they were there!
No Problem, glad you were able to find it!!! :)
1 - 15 of 15 Posts
