1 - 3 of 3 Posts
For those of you lowering your bike does the rear drop more than the front?
And if so, does that mean that most of the oil goes to the rear of the pan. Think that will cause a problem down the road?
Well,,, I believe most are just doing the rear, so yes, it would go to the rear of the pan. I'm getting some fork extensions, so it will be even worse. The good thing is the little sit window, you fill to the level so that shouldn't be a problem. The real question is will too much oil be a problem down the road! Deja has both the drop,and the extensions she could probably chime in on this?
1 - 3 of 3 Posts
