Re: PCS Lowering Connectors
48401 Views 176 Replies 63 Participants Last post by  BrettRTR
8
The PCS directions were mediocre but installing these was not that bad. Here are some tips, and I
will plug in the photos of progress later.
1) I removed the upper and lower belt guards to make life easier. Two things, the upper and lower bolts on the rear of the guards do not need to be removed since they are only attached to a backing plate, and it’s easier to remove the lower guard by turning it upside down in place,,,just make sure you don’t lose the little bushings.
I found it helpful when aligning the lift under the frame to put blocks under the kickstand to stand the bike upright.
2) I used a long box end wrench on the right side of the dog bones wedged against ground or swing arm and a ratcheting box end on the left. Once the left bolt broke free it was easy.
3)I found that placing different sized boards under the rear tire and working the lift height made removing the dog bones and bolts a snap. The bushing on both can move quite a bit and is necessary to clear the frame on the lower bolt ,and the coolant reservoir on the top bolt.
4) Putting the new connectors on is the reverse operation. PLEASE note – the end of the connectors with the round hole goes on the top. This had me scratching my head for a minute since it is not mentioned at all in the instructions. Both connectors need to face the same way and the longer detent faces the front of the bike. I found it easier to put the bolt in at the bottom first and then do the top.
5) I put loctite on the threads and finger tightened the nuts(don’t forget the washers). I ratcheted down the nuts enough to allow just a little play in the connectors. Lowering the jack a bit seated the connector and I then tightened it completely.
6) Put the belt guards back on and set the bike back down on the ground.
The 1 inch drop is not that noticeable in the picture, but I can now plant both feet firmly on the ground wearing flat shoes and I have an inseam of 30 inches. One person can do the job, but 2 would make it much easier. Any questions….just let me know.
161 - 177 of 177 Posts
If you ride 2-up or have your rear shock preload set low- you will most likely have problems with the links set at 2-1/4 with even the 240 tire.. Many have found that out already. with the 240, you may only need to add washers between the lower guard and their mounting bracket to eliminate any scuffing. The 250, you will have to do some trimming of the lower guard and maybe add washers between your upper guard and their mounts. Also keep in mind the different heights of each brand of tire. Avon is lowest, Metzler & Michelin midway, and Dunlop being the tallest of the 240's. You only have the option of Avon or Dunlop for a 250. This is pic with 250 Avon on 8" PM wheel: http://www.yamahastarstryker.com/me...s-11stryker-s-ride-picture6394-52013-007.html And a pic of my 260-35R18 that I am running on 9-1/4" widened rim now: http://www.yamahastarstryker.com/me...4-widened-rim-picture24330-dscn1088-copy.html Here is pic of 240 Avon on 8" PM wheel:
I know this is for lowering the rear but does any one know if there is a 1" lowering kit for the front as well? I would really prefer to do both over just the rear as that is how I had my Vulcan 900
Just loosen your pinch bolts on the triple trees around the fork tubes and slide
the whole forks up through the trees an inch and then retorque the pinch bolts. you will want a bike jack to hold bike while you are doing this.
It's really that easy and not going to mess anything up
Seriously that easy.:nod: Just consider that it will be extremely easy to scape pegs lowering both front and back of bike. More so because of the lowering in front.
Do you have any pictures of what it looks like? I'M moving my pegs forward as well. I have the kit but can't do it till next weekend
I have 2" fork extensions on mine. Opposite of what your looking to do.
Where did u get the fork extensions?
Sent from my iPhone6+ using Tapatalk
http://www.billskimods.com/ForkExtensions.htm
Cool thanks!
Try the lowering kit that Shane at sscustomcycle sells for the front forks.
http://www.sscustomcycle.com/products/hardcore/Yamaha/Stryker.shtml
I just ordered the pcs links as well as a kit to lower the front trying to decide if I'm going to go 1" all the way around or 2"s all the way around. Any worda of wisdom
Scrape scrape
Lowered her 2"s all the way around and so far I love it. Only scraped a couple times so far but I did modify how I ride a little.
