To remove the pegs there is just a cotter pin in a pin. Tf you are removing the mount I think it just bolts on?Natedog said:How did you guys manage this? Man! Its like they're welded on there. Do you use an impact gun or something? They aren't reverse thread are they?
Yepercanyon1 said:Now you're gonna be sorry if you chance upon a stranded damsal who needs a lift....
This is good to know.Alaskanmonte said:Took my passenger pegs off this week. Three bolts came out fine but on the fourth my t-handle hex wrench broke. The broke tip was stuck in the bolt head. I had to drill it out and in doing so I messed-up the bold head. Ended up drilling the center out and using a reverse dill bit (EZ-OUT) to get it out. It was a pain in the butt.
Yamaha definitely did not want these falling or vibrating out. They were all covered in lock-tight. Use a quality hex bit and take your time.
