I bought it waaaayyyy out of state.sanderclause said:
I bought it waaaayyyy out of state.sanderclause said:BTW the Dealer should have given you a tool bag when you bought the bike to accomplish this easily on your own.
What's that supposed to mean?11Stryker said:Yes and reading owner's manual will help also!
Thats the way I do it!11Stryker said:Jack it up, take both small side covers off right side, use a long screwdriver and tap lightly with hammer in slot of adjustment ring to adjust. 5 minutes top!!
Were you softening or stiffening?Natedog said:Thats the way I do it!11Stryker said:Jack it up, take both small side covers off right side, use a long screwdriver and tap lightly with hammer in slot of adjustment ring to adjust. 5 minutes top!!
Not to speak for 11 but the manual explains the process pretty well.immortal13 said:What's that supposed to mean?11Stryker said:Yes and reading owner's manual will help also!
Btw, the bike was on a motorcycle jack. He tried with a big pair of channel-lock pliers and claimed it wouldn't move. Guess I'll try the hammer and screwdriver technique. I'll have to go back by the shop because I don't have a motorcycle jack.
I have adjusted both ways for i or 2up riding.immortal13 said:Were you softening or stiffening?Natedog said:Thats the way I do it!11Stryker said:Jack it up, take both small side covers off right side, use a long screwdriver and tap lightly with hammer in slot of adjustment ring to adjust. 5 minutes top!!
I read the dang manual.....AND I took it to a bike mechanic. I have a totally reconstructed right wrist, so some things aren't easy for me to do anymore....hence the mechanic. For some reason, this jakeleg can't seem to turn the **** thing and I'm trying to understand why. Yes I'm frustrated LOL. If I have to drive 30 miles to the Yami dealer, wait forever, and overpay to get it done I'm going to be really pissed.sanderclause said:Not to speak for 11 but the manual explains the process pretty well.immortal13 said:What's that supposed to mean?11Stryker said:Yes and reading owner's manual will help also!
Hey Friend, you and I need to live nearer each other! I will help you with the mechanical and you help me with the electrical. We could both save some money!!immortal13 said:I read the dang manual.....AND I took it to a bike mechanic. I have a totally reconstructed right wrist, so some things aren't easy for me to do anymore....hence the mechanic. For some reason, this jakeleg can't seem to turn the **** thing and I'm trying to understand why. Yes I'm frustrated LOL. If I have to drive 30 miles to the Yami dealer, wait forever, and overpay to get it done I'm going to be really pissed.sanderclause said:Not to speak for 11 but the manual explains the process pretty well.immortal13 said:What's that supposed to mean?11Stryker said:Yes and reading owner's manual will help also!
Thanks for all the helpful tips. I'm going to try the screwdriver method
We get ya man, we just want to help. tough luck with the wrist that sucks. I'm a mechanic so I forget sometimes this stuff does not come naturally for some. Anyway giver **** with the screw driver. Also you can carefully take just the weight off with a regular car jack and try it that way. "carefully"immortal13 said:Lol 11....maybe that's what we need to do.
Really, I'm frustrated because it seems simple but this **** bike mechanic can't even do it....wtf?????
And use a piece of thin wood or rubber on the jack as well so you don't scratch the bottom of the frame.11Stryker said:Hey Immortal, Good idea having friend hold bike for you. just put screwdriver against side of a hole that you want to move sleeve toward. Should be relatively easy with weight off rear wheel. Try to keep jack back far enough so that you only raise rear wheel off ground.
Let us know how that works. I too am having problems getting it to turn in the direction to tighten it up. Like I said before the mechanic at the dealer loosened it in the parking lot on the kick stand with the tool they gave me when I bought the bike. But I couldn't get it to move and the mechanic at the tire shop couldn't either and he had it up on his lift and I watched he push real hard and the hole thing moved but it would not click into the next notch. I wonder if the lowering links make it harder. And no you should not have to take anything off to get the tool on it except the side cover.immortal13 said:Will do Sander. Thanks for the tips guys. Looks like I didn't need the stupid spanner wrench then.
Didn't have time to look at it today, but I will post when I do.Toby said:Let us know how that works. I too am having problems getting it to turn in the direction to tighten it up. Like I said before the mechanic at the dealer loosened it in the parking lot on the kick stand with the tool they gave me when I bought the bike. But I couldn't get it to move and the mechanic at the tire shop couldn't either and he had it up on his lift and I watched he push real hard and the hole thing moved but it would not click into the next notch. I wonder if the lowering links make it harder. And no you should not have to take anything off to get the tool on it except the side cover.immortal13 said:Will do Sander. Thanks for the tips guys. Looks like I didn't need the stupid spanner wrench then.
Ok maybe the links are causing too much presser on the spring to allow it to turn especially to tighten it?immortal13 said:Toby said:Let us know how that works. I too am having problems getting it to turn in the direction to tighten it up. Like I said before the mechanic at the dealer loosened it in the parking lot on the kick stand with the tool they gave me when I bought the bike. But I couldn't get it to move and the mechanic at the tire shop couldn't either and he had it up on his lift and I watched he push real hard and the hole thing moved but it would not click into the next notch. I wonder if the lowering links make it harder. And no you should not have to take anything off to get the tool on it except the side cover.immortal13 said:Will do Sander. Thanks for the tips guys. Looks like I didn't need the stupid spanner wrench then.
That's exactly what was happening with my mechanice. He guessed maybe the lowering link were the prob.....??
