For solo riding, what do people have the shock set at? I am about 250 lbs with gear on.
Just break out your tool and with your left hand drink a beer. With your right, keep pushing that tool all the way to the right in a perpetual motion until you hear a thunk. If you hear a thunk start over and stop just before the thunk. If I am telling you wrong, switch hands, start over and change direction.For solo riding, what do people have the shock set at? I am about 250 lbs with gear on.
After all that I'd be on at least my second beer!Just break out your tool and with your left hand drink a beer. With your right, keep pushing that tool all the way to the right in a perpetual motion untill you hear a thunk. If you hear a thunk start over and stop just before the thunk. If I am telling you wrong, switch hands, start over and change direction.
190 lbs plus gear, 240 tire and lowered 1 1/2". I set it at notch 8.For solo riding, what do people have the shock set at? I am about 250 lbs with gear on.
Ok, how many beers (drinks) did it take you. well worth adjusting!Second easiest adjustment I have done! She likes it hard! #9 for 435lbs
Two! One when I got the tools and one more when I went to get the pipe for leverage walked past the cooler anyhowOk, how many beers (drinks) did it take you. well worth adjusting!
You need the shock wrench (Spanner) that came with your bike's tool kit.What size spanner wrench do I need. 1/2 to 2" work??
Clever... and thanks for the video!Here's a Quick Video on how to easily adjust your rear shock with just your hand,... Enjoy!
Id think lowered vines would be impossible to adjust because the shock is always compressed. Man that sounds like fun. They call for a battery denial in the official Yamaha repair manual...i used to adjust all the time from the side of the bike no problems.So I tried to adjust with my hands and no luck. This was my third time trying to adjust that mofo. I rode down to the dealership today and was not able to find the oem adjustment tool so I bought a double sided tool that ended up being way too long. I had to cut the tool in half and then weld on a piece of steel at a 90 degree angle. After I jacked the bike up AND removed the dog bones AND sprayed everything with wd40 I was finally able to adjust the spring three turns tighter(using one hand to crank and the other to hold the tooth in the notch) before the tooth on the end of the wrench broke off...notch 7 it is!
The "5 minute" job only took me 2 hours of wrenching, 2 hours of riding and $12.
