With the help of Roger on this board I removed the dust cover on the rear disc. Only took about 30 min to complete and very easy. All you need is a dremel tool, 1 1/2 inch metal cutting disc and some wooden wedges. You will also need six washers to put on the screws you remove before putting them back on after removing the dust cover. I will explain the procedure on each picture. Maybe this will be helpful to others like me that need a little help. Actually I usually need a LOT of help. The first picture is before anything is done.
