I'm about to cut the ducktail off the rear fender and want to convert the turn signals with one of the run, break, turn conversion kits. I've found the kuryakyn and one on baroncustom, but wanted to check with ya'll to see if you had any opinions on which is better or if you knew of any that work for less then $80.
