1 - 9 of 9 Posts
I was on my way to work this morning when I noticed that my running lights were not on, any of them. My turns and brake light still worked as did the headlight. Anyone know of the top their head if there is a fuse for just the running circuit? I'm hoping that's all it is.
Straightjacket said:
Looking at your mods I'd start with the connections you made when you were doing your lighting? Maybe you have a loose connection, or a wire rubbed through somewhere? On headligh bulb, or under rear fender, and shorted?
I would agree with Straightjacket.. probably a connection somewhere.
That's what i suspected at first but when I saw that my turns and brake still worked I figured that may not be issue.
Thanks for the inputs guys, I'll have to take a look at this weekend. I just hope I don't get a ticket on the way home for no tail light.
I took a quick look at it while on lunch. It was the 10A fuse for the tail light. Easy fix.
Its good you found the result, but what was the cause? Perhaps you need to up the fuse to a 15A to deal with the extra draw from the fog lights, or maybe there is still a short somewhere. Keep an eye on it. ;)
1 - 9 of 9 Posts
