1 - 7 of 7 Posts
Hello guys,
I have the passenger backrest with the quick realesa on my stryker and i'm trying to install the saddlebags support but the screws are not longer enough. By any chance, somebody knows the right size of the screws to be able to use both accesories at the same time.
thank you.
I have the 4 original stock bolts for that exact setup that I will give you. Just pm me your address and I will mail them right out.
I have the same backrest with M8 65 cm bolts.
My easy backet (for my saddle bags) arrived with the wrong bolts so I measured the mount (1.5 cm) and found some M8 80 cm bolts with hex top. They worked fine for now.
Waiting on replacement stainless 80 cm from easy bracket which are in the mail now.
Like he said above measure original bolt and add thickness of bracket. You should be able to find hex top M8 bolts at any industrial supply store.
Good Luck!!
The stock bolts he would need for his setup are Allen head screws which fit into recess of Star support bars. Hex head would have to be a bit longer, need a washer and not look as well as the stock bolts that will fit into the recess of the Star support bars.
I bought all my parts through my dealer at a 45% discount from suggested retail. (About the same discount he gives me on all of my purchases). I did take a trip back to the dealer to get the longer bolts, but he threw them in free They are two 80mm x 8 x 1.25 for the front and two 90mm x. 8 x 1.25 for the rear.
Sent from my iPhone using Tapatalk 2
1 - 7 of 7 Posts
