kraaazymike said:Ok, I'll bite. Front turn signals are from Chrome Glow. They are the LED fork wraps with the running light circuits.
http://www.chromeglow.com/catalog.asp?prodid=740354&showprevnext=1
Don't mind the little hole that leaks light above my left brake light. It was a bad choice in prior experimentation with mods. Also, I added music to this because I felt listening to me walking around and the turn signal clicking was lame.
This setup doesn't require any additional resistors or any load equilizers (which is just an expensive resistor). Just follow this guide: [url=http://www.yamahastarstryker.com/index.php/topic,2358.0.html]http://www.yamahastarstryker.com/index.php/topic,2358.0.html[/url]
[/quote]
I'm gonna run the same front's but I'm not gonna use them as running lights. I'll just have em wired up to blink on when i hit the indicator switch and then stay off the rest of the time.
Do it! And you'll save $21.99 while youre at it!skwerlee said:I'm gonna run the same front's but I'm not gonna use them as running lights. I'll just have em wired up to blink on when i hit the indicator switch and then stay off the rest of the time.
SCHIMBO said:Custom Turn signals and Low and mean brake light
[img]
[img]
[/quote]
Are your rear signals on the end of the swingarm?
j4patrice said:Low and Mean taillight mod and Radiantz license plate.
[/quote]
J4patrice, am I seeing that your setup has the white plate light? Was that part of the L&M kit or ? Is that little strip of light visible in daylight?
Thanks,
Sci85
Sci85 said:j4patrice said:Low and Mean taillight mod and Radiantz license plate.
[/quote]
Thanks,
Sci85
[/quote]
Yes, it is coming from the Radiantz license plate. Here is a link.
[url=http://www.bikerhiway.com/radiantz-real-flex-integratorz-1-plate-frame-p-1993.html?utm_campaign=frgl&utm_medium=frgl&utm_source=froogle&gclid=CJyqi5HA0a8CFcHJKgodIDcIHw]http://www.bikerhiway.com/radiantz-real-flex-integratorz-1-plate-frame-p-1993.html?utm_campaign=frgl&utm_medium=frgl&utm_source=froogle&gclid=CJyqi5HA0a8CFcHJKgodIDcIHw[/url]
I need those. What did you get? I want to make my taillight brake and run only and have the blinkers moved. Brake light and blinkers on my bike really aren't enough right now.SCHIMBO said:
