1 - 4 of 4 Posts
Hello,
Is it still possible to have your license plates mounted to the side of the motorcycle if there are saddle bags in place? I'm looking to get some Vikings warrior leather bags size medium but would like to relocate my license plate to the side. Will this work with a saddlebag setup? Thank you
· Administrator
I made a custom mount that attaches to the rear adjuster bolt as I didn’t like the axle mount one . Also wired for light as that is required in PA.
Tire Fuel tank Wheel Automotive tail & brake light Automotive lighting
Thank you for sharing and providing a photo!
How did you make a custom bracket, did you buy a license plate holder and modify it to be able to mount to the adjustment bolt? Also, is there a specific way to mount it to the adjustment bolt or can I easily remove the bolt and torque it back on? Will this change the alignment of the rear wheel?
· Administrator
Sorry for late reply, yes I bought a plate and frame mount and welded a bracket with Stainless washer to attach to bolt then bought two more nuts and use blue lock tight on BBC all nuts- to keep them from vibrating loose. I have it put away for winter best pic I can get now is this.
Hood Automotive tire Bumper Automotive lighting Automotive exterior
1 - 4 of 4 Posts
