ok guys, i didnt like the sound of it drilled out, so i removed the baffles, check it out.......i like it! http://www.youtube.com/watch?v=2AJhYRVICoY by the way, i did not remove any cat material.......
did you listen to it after removing the baffles but before the cat removal? does removing the cat material make much difference with the baffles out?mx918mx said:You aren't kidding when you say this is a pain. I did the same to mine along with removeing the Cat which was also quite a task. I had the same issue once I broke the baffles loose they wouldn't slide out due to the flange. Used a long 3/8 drill bit and a long chisel to basically do the same thing you did, but man love the sound diff.
if you mean the inner plate the baffle was welded to, some of it is still there, but i will clean it up a little more. it does pop occasionally, but i like the new sound more every time i ride, and im getting lots of compliments on it, usually "wow, thats sick" lol. im going to get a bud to ride it by me so i can hear it at a distance and in passing. i have only heard it from the seat......Straightjacket said:So the inner flange is still in there? Sounds like it's pretty reamed out if it is. How is it on the long decels, does it pop really bad?
Unfortunately I did not. I actually pulled the mufflers off to do the CAT removal. Once I finished that I said what the heck and removed the baffles as well. So I am not sure if there is much of a sound difference with the CAT mod once the baffles are out.redcop said:did you listen to it after removing the baffles but before the cat removal? does removing the cat material make much difference with the baffles out?mx918mx said:You aren't kidding when you say this is a pain. I did the same to mine along with removeing the Cat which was also quite a task. I had the same issue once I broke the baffles loose they wouldn't slide out due to the flange. Used a long 3/8 drill bit and a long chisel to basically do the same thing you did, but man love the sound diff.
