Nice. I was wondering how to get the grips off when mine get here tom.
If Mikoloe were to respond.
Open new 12 pack and drink two beers
At the bar ends there is a small cap, gently pry these off. Under these caps is a hex wrench bolt. Remove the hex bolt and the bar end weights will come off exposing the grips.
Drink another beer.
On the clutch side just slide a small flat screwdriver between the rubber grip and the handlebar to break the seal between the grip and the handlebar. You will have to do this all the way around the grip.
Crack open another beer.
The throttle grip is held in place by a slot and grove system on the stop/start cluster (I am sure there is a formal name.) Unscrew the back of the cluster unit which can then be spread apart and allow the grip to come out of that track. Then remove your throttle cables. Just note which was the upper cable and lower before you total remove them. Drink another beer
Install grips per instructions, and have a beer per side. Stand back, admire your work while drinking a beer.
