1 - 4 of 4 Posts
I have ordered the fork tube covers from low and mean and i thought in their install video they had the torque settings but i was wrong. Does anyone know the settings when putting the front tire and axle back in place? Thank you for your help in advance
Front wheel axle - M16 - 1 - 72 Nm (7.2 m·kg, 52 ft·lb)
Front wheel axle pinch bolt - M8 - 2 - 20 Nm (2.0 m·kg, 14 ft·lb)
TIP
1. Insert the front wheel axle from the right side and tighten it to 72 Nm (7.2 m·kg, 52 ft·lb). Check that the left end of the front wheel axle is flush with the front fork. If necessary, manually push the front wheel axle or lightly tap it with a soft hammer until its end is flush with the front fork. How-ever, if the surface of the front wheel axle end is not parallel to the surface of the front fork, align a point on the outer edge of the axle with the fork, making sure that the axle does not protrude pastthe fork.
2. In the order pinch bolt “1” → pinch bolt “2” → pinch bolt “1”, tighten each bolt to 20 Nm (2.0 m·kg, 14ft·lb) without performing temporary tightening.
The service manual can be found on one of the threads here, you should download it this way you have all the torques and specifications. :thumb:
1 - 4 of 4 Posts
