1 - 2 of 2 Posts
I bought a "universal motorcycle metal luggage rack base plate for mounting trunk rear case" off eBay for $32 and a "Universal X-Large motorcycle scooter trunk luggage top case hard tail box black" from eBay for $51.95. I went to Home Depot and bought 2 1" x 1/8" flat steel for around $10 total. Painted with VHT high temp engine paint ($8 from Advance Auto) and baked in oven per directions on can. Some miscellaneous fasteners for around $3 at local store and these are the results. The trunk is big enough for 2 full faced helmets. I need to replace the allen bolts as I got the wrong ones as they are already starting to rust a bit as you can see in the pictures. Not a bad addition to my Stryker for around $105 and a few hours cutting, grinding and painting.
1 - 2 of 2 Posts
