Please use the search button. If you put any effort at all into doing a little reading around on this forum before you posted this you'd know that this has been talked about hundreds of times.jrome46 said:I was told that the stryker would accept a 235 back tire. Has anyone gone larger and how is the performance on corners with a larger tire?.
What Brand 235 are you looking at?jrome46 said:I was told that the stryker would accept a 235 back tire. Has anyone gone larger and how is the performance on corners with a larger tire?.
Our very own search policeskwerlee said:Please use the search button. If you put any effort at all into doing a little reading around on this forum before you posted this you'd know that this has been talked about hundreds of times.jrome46 said:I was told that the stryker would accept a 235 back tire. Has anyone gone larger and how is the performance on corners with a larger tire?.
http://www.yamahastarstryker.com/index.php/topic,347.0.html
Haaa Thats Funny.... But not to be a "Richard" Y in the **** would you go with a 235???? 240 or 250 ALL THE WAY SON!!!skwerlee said:Please use the search button. If you put any effort at all into doing a little reading around on this forum before you posted this you'd know that this has been talked about hundreds of times.jrome46 said:I was told that the stryker would accept a 235 back tire. Has anyone gone larger and how is the performance on corners with a larger tire?.
Well to answer the Why? One reason would be like what I am looking for, the best tire size option to keep the configuration, 2.25" drop ride 2 up plus fully packet close to max load limit of 450 lbs, without having to remove parts and grind the swing are etc. That's why I am curious of what brand tire it was if he found a 235 that would fit the Srtyker rim, bike tire or car tire so I can research it.WLFPAK65 said:skwerlee said:Please use the search button. If you put any effort at all into doing a little reading around on this forum before you posted this you'd know that this has been talked about hundreds of times.jrome46 said:I was told that the stryker would accept a 235 back tire. Has anyone gone larger and how is the performance on corners with a larger tire?.
I think that is a tall order Toby ... dropping it 2.25, riding 2 up with 450lbs ...Toby said:Well to answer the Why? One reason would be like what I am looking for, the best tire size option to keep the configuration, 2.25" drop ride 2 up plus fully packet close to max load limit of 450 lbs, without having to remove parts and grind the swing are etc. That's why I am curious of what brand tire it was if he found a 235 that would fit the Srtyker rim, bike tire or car tire so I can research it.![]()
You might be right dreadly, 450 lbs is the max load the bike will take under average road conditions that you might encounter that with the preload set at #9 would not allow shock to bottom out. I have already had approximately 400 lbs with the 210 /2.25 drop and preload at #1. Only barely bottomed out once on a pretty good pothole. But that was an improper setting on the preload for that much weight. The tail pipe was a bigger problem on corners. I believe it's been confirmed that an Avon 240 /2.25 drop preload set at #7 did not rub with 320 lbs, If I'm correct the preload is designed to keep the shock from bottoming out at maximum load set at #9. Even with a 2.25 drop the shock system should not allow it to compress more than it's designed to at max load. Unless you hit a really big hole. And God knows we have those up heredreadly said:I think that is a tall order Toby ... dropping it 2.25, riding 2 up with 450lbs ...Toby said:Well to answer the Why? One reason would be like what I am looking for, the best tire size option to keep the configuration, 2.25" drop ride 2 up plus fully packet close to max load limit of 450 lbs, without having to remove parts and grind the swing are etc. That's why I am curious of what brand tire it was if he found a 235 that would fit the Srtyker rim, bike tire or car tire so I can research it.![]()
PCS is specific to Yamaha , Pacific Coast Star.dreadly said:Toby ... the theory sounds good.
I personally think the 2.25 drop is a lot and wasn't meant for riding like you are going to be doing. If it was Yamaha that put out the lowering product, there might be some value in doing the math. Just my opinion though. I am interested in hearing how you fare.
LOL i know it man...i think there's something wrong with mesnowman68 said:Our very own search policeskwerlee said:Please use the search button. If you put any effort at all into doing a little reading around on this forum before you posted this you'd know that this has been talked about hundreds of times.jrome46 said:I was told that the stryker would accept a 235 back tire. Has anyone gone larger and how is the performance on corners with a larger tire?.
http://www.yamahastarstryker.com/index.php/topic,347.0.htmlI'm not bashing but you alway get the jump one everyone else with posting that lmao
Yosemite I'm glad you brought this point up. It's one more aspect that has to be clear on this subject.Yosemite said:With 2.5 inch drop I'm sure the stock tire would rub before the shock bottomed out. Setting the pre-load to 9 wont prevent it from bottoming out the shock it will just make it more difficult to do so since your technically just increasing the spring rate a little bit. But then again with 2.5 inch drop i'd be more worried about the the fender supports bottoming out on the tire.
Go with the 240/40/18 Avon Cobra....it works great, double the mileage over the stock Metz, better handlingjrome46 said:I was told that the stryker would accept a 235 back tire. Has anyone gone larger and how is the performance on corners with a larger tire?.
So 11Sryker, where the geometry changes then is, the ANGLE in which the links cause the fender to approach the top of the tire. That's why it hits a different spot than it does with the stock dog bones which causes it to come STRAIGHTER down. After looking at the rear suspension system I could see that there is a pivot point that the shock actually rocks on when depressed. With the PCS links set at 2.25" it pulls the frame FOWARD and down. The 1" slot is in a different spot that changes the angle of the links closer to the angle that the stock dog bones are at. So it's not so much a matter of clearance as it is the change in angle. Does that make sense?11Stryker said:Hey Toby, You are changing the geometry of the rear suspension with the lowering links which will enable the stock tire to hit under fender under certain conditions, which will not happen with stock dogbones.
