I've been nervous to post this for quite awhile, but I talked with a mechanically inclined co worker today about the recent issue on my bike. Ever sense I put the Staggered pipes on my bike, in 2nd and sometimes 3rd gear the engine will cut almost all power for a breef instant. I'm talking before you can count to 1 second it's back and working great. It only happens if i'm in 2nd/3rd and reaching a bit higher in the tachometer. I really didn't change my shifting style with the new bike, and i'm not reaching the max RPM for that gear as I can give it more and it's fine. It only happens randomly, and the coworker stated that it's due to the pipes and I need a Tuner.
This makes sense to me, as most members on the forums do not run with the Staggereds, and they seem a big bigger than the Swepts. Does this seem correct to you guys/gals? The bike runs as smooth as can be in 1st, 4th, and 5th gear(and about 100% all gears ok if i cruise at normal speeds. Only happens when i'm giving it a bit prolonging a shift just a bit)
