1 - 11 of 11 Posts
I went out of state this past weekend and once returning home, I obviously had to get the Stryker out. Well when I went to start it, it sounded like the battery was low on juice, but not so bad that i thought anything of it. Rode it for a few miles and parked it for the night.. Following morning I go to start her up to take off for work, and it's now like the battery is almost dead... I pressed the start button and the motor wound, very very slowly and stopped. I then released the button.. and pressing it again got it to fire up. I drove it to work parked it there and let it sit for a few hours until lunch time today. Got on it at lunch, started right up no problem... drove up to the gas station < 2 miles from my place of work to get a drink turned it off came back out and did the samething.. sloooowly the motor wound until it quit, i released the start button pressed it again and it fired up. It happened once more on a shorter ride today as well. I'm curious as to whether anyone else has had this issue or what it might be, I think its the battery but the way it's acting Im just not sure.. the only electrical modifications I've made are installing an HID kit, and it's been on the bike since last year with no issues so I know it's not a faulty wiring job if that would even affect it.. Thanks in advance for any information and help on this.. It's so upsetting because it's only got 2k miles on her.
I'm guessing you are waiting for the needle to do its sweep when you turn key to on position before you hit the start switch. So you may just have a loose or corroded battery connection. Check those and for loose connections at starter. My best guess anyway!
well, I just went outside... after riding it home for i'd say 25 miles.. started RIGHT up. check all the connections from my battery to the starter, All are good connections. I started and stopped it 3-4 times quickly and rode it for about 30 seconds. Stopped turned it off, tried starting it and it fired right up again... I have no idea, right now it seems like it's fixed itself? Or... I had a pixie on my motorcycle. If it happens again later in the day, or tomorrow morning.. I'll re-post in this thread with further details, but I just tried to kill the battery on purpose and its starting like its brand new again...
Discussion Starter · #9 ·
Thanks guys. I'm going to give it another day, if it happens again like I said.. I'll fill you all in. Thanks again fella's. Really appreciate this board and the members, you guys are great, Ive not posted often but when I do you're all on top of it and willing to help, wish the whole world could be this way!
Well don't be a stranger usually I ask a bunch of stupid stuff that's already been asked or talked about yesterday and forgotten it. Have to ask again. I think of it this way have to stay stressed all day at work this is my relax place where a bunch of guys just hang out. Nobody has got mad at me yet
Check the normal stuff and if you have a tender throw it on. Look for lose or corroded connections. Good thing is that batteries and the connections are pretty good about telling you if something is wrong.
Had a few instances where I killed the bike while riding and it didn't want to start w/ the clutch pulled in and in gear but that is more like it gets caught between a compression stroke. Moving the bike a little helps that but if in neutral that shouldn't be the case.
If this continues there is a good YouTube video on checking the battery and what the voltages should be at X points. To test the starting capacity you need to pull the fuel pump fuse so it cranks but doesn't start.
If you stored it improperly over winter/non-riding season the battery could be toast but some chargers can bring them back from the beyond... Bottom line is that anything over 2-3 weeks probably needs a tender to keep things happy. And if the non-load reading is anywhere near 10 volts you have a dead cell and crapola battery:(
Post back and let us know.
1 - 11 of 11 Posts
