1 - 18 of 18 Posts
Nice Job Bro! Now the upper and lower triple trees?
Looks great. I may have to do this on my 2011 reddish copper now that I've seen how it looks. Thanks for the visual!
Sent from my DROID RAZR using Tapatalk 2
Do it! The key with the Plasti Dip is patience. I did 6 or 7 lite coats allowing 10-20 minutes to dry between coats. The first coat needs to be extremely light...maybe only 30% coverage. After 3 to 4 lite coats it'll all start to come together nicely.
Discussion Starter · #11 ·
I'm assuming you aren't using a self etching primer or anything in case you wanted to peel off the plasti dip later? So are you just degreasing and then coating the plasti dip?
I just washed the forks and then rubbed them down with isopropyl rubbing alcohol. If you spray the first coat extremely lite it will dry and act as a sort of "etch" for the additional coats to adhere to. Plasti Dip is 100% removable and will not damage the original finish at all. Its just a protective rubberized coating.
Discussion Starter · #13 ·
WOW looking awesome.. and not so much expensive as you are saying its only 7 bucks.. but now your bike looking gorgeous, I like the idea, thanks for sharing the photos. You bike is really very beautiful.
Thank you Marvin I appreciate it! There are several Plasti Dip how-to videos on YouTube that I found very helpful.
I asked someone at my local bike shop about plastidipping the lower forks, and was told I couldn't because that would obstruct the motion of the forks' movement to absorb shock. After hearing that I began considering the Low and Mean fork and gator covers, but those are $150.
Doing the fork lowers as I did has zero affect on suspension operstion. The shop must've thought you wanted to coat the fork tubes themselves.
I wouldnt mess with that part of the forkes. Get you some shop vac hose and slide it in.
1 - 18 of 18 Posts
