Is it just me or do anyone else forget what gear they are in from time to time when shifting :-X ??? ? Maybe Yamaha should add a tach or gear indicator on the next year model. :-[
Kakarot said:I use the engine sound to know if I'm in a sweet spot or not, only the 5th gear fools me.... Seems like it should have 6![]()
+2Raven said:Kakarot said:I use the engine sound to know if I'm in a sweet spot or not, only the 5th gear fools me.... Seems like it should have 6![]()
+1
I've said for a long time that his bike should have had a sixth gear
+ 4Mithros said:Kakarot said:I use the engine sound to know if I'm in a sweet spot or not, only the 5th gear fools me.... Seems like it should have 6![]()
+3
If I am 85, I will hold 85!!!ROADKILL said:You might want to try this to get the engine sound to level out a little better - I've noticed that if I run the bike up to let's say 80 mph and hold it there it sounds like it's working hard or I need to upshift - what I do now is if I want to run 80 I run it up to 85 and then slowly roll off the throttle to 80 and the engine seems to level off - doesn't sound like it's working too hard....just a thought.
Yea, it's the only tricky one... because your go into 5th after 90-190kms.... so the revs get noticeably higher... however, when I play with the clutch a little.... I can tell its in 5thStrykenShane said:I'm always looking for 6th gear
+ 5galo8 said:+ 4Mithros said:Kakarot said:I use the engine sound to know if I'm in a sweet spot or not, only the 5th gear fools me.... Seems like it should have 6![]()
+3
+1StrykenShane said:I'm always looking for 6th gear
strykermac said:+ 5galo8 said:+ 4Mithros said:Kakarot said:I use the engine sound to know if I'm in a sweet spot or not, only the 5th gear fools me.... Seems like it should have 6![]()
+3
+6trochero said:strykermac said:+ 5galo8 said:+ 4Mithros said:Kakarot said:I use the engine sound to know if I'm in a sweet spot or not, only the 5th gear fools me.... Seems like it should have 6![]()
+3
