1 - 8 of 8 Posts
I'm thinking about getting a front wheel chock/stand for my Stryker. I believe it would be helpful for checking the oil level since the bike must be level to get a read on the oil. Also, I could use it when I need to do things on the rear wheel like adjusting the belt tension etc.
Harbor Freight sells one for about $40 but I haven't seen it yet. Anyone out there have one yet or an opinion on them? I'm hoping that I can find one that will work with the 21" front wheel.
Yeah, dliszews, the second one is what I had in mind. I like to keep an eye on my oil level and without someone to hold the bike upright it is hard to get a reading. This one looks sturdy enough to do the job and I have a coupon for the discount. Anyone out there in Strykerland have one of these or use something else ?
Canyon1, bought the black one for the garage yesterday. Easy assembly and pretty sturdy.
Added some washers on both support to make it better. They use two metal rods that give
it too much play. It does slide on a finished concrete floor but a piece of rug/mat resolves that.
The tie down hooks are decent and would suggest using them when wrenching the bike.
Could it be bolted to like a trailer floor?
Toby, you bet. there are mounting holes in the base already. It has 2 cheap feet at the front
which should be removed so that it mounts flats. As an FYI, if you are going to mount the other
one mentioned works well. I have 2 of those on my trailer.
Great thanks for the info dliszews.
1 - 8 of 8 Posts
