1 - 6 of 6 Posts
Just a quick question. Does anybody know off hand, if the rear turn signals are 2 or 3 wire? I can check when I get home, but I'm at work and want to buy new Red rear turnsignals.
Thank you
The rear turns are only 2 wires coming from the factory. Turn, and ground I believe they are brown, green, and black for gnd.
If you want them to be running lights you'll need a duel element deal, and wire the running light to the brakes running light.
Thanks Jester! I've already installed the run, turn, break conversion kit and now I've been shopping around for some nice small yet bright LED bullet style lights. You answered another question that I didn't even know I'd have ;D
What is this "run, turn, brake" conversion that I keep hearing about?
The stock rear turns do not run unless they are flashing. The conversion is just to make the turn signals also running lights.
The chromeglow one is a simple option, but I think you could do it cheaper individually. I know the LM rear signals came with the wiring minus the load equalizer.
The load equalizer will just bring you lights back to the stock flashing speed.
1 - 6 of 6 Posts
