My 2011 Stryker will not recognize neutral.......... does anyone have any ideas on how to fix this? I have tested everything to see what it does and all switches are operating....... need advice!!!!!! The neutral light does not come on anymore.
Ok thsnk you Stryker 2012....... I needed to find a way to check the light........ as far as voltage..... no just continuity.........The neutral light is part of the safety circuit. If the LED is bad, it will keep the circuit open to the neutral safety switch, and can be overridden by the clutch switch. Jump the wire for the light at the connector to ground. If the LED lights you know it's definitely a bad switch, if not, replace the LED.
You said you checked the continuity on the switch, did you check voltage?
Just to be clear the bike physically goes into neutral? By that I mean with it off shift into neutral and test to see that the bike moves. If not I believe there were threads on adjusting the clutch cable to make this happen easier.
Assuming the bike moves, I believe there are a number of the safety switches that all plug into the starting relay(?) and some probably override one another. Others would have to post and test on that aspect but I think you definitely need to have the kickstand up and the kill switch in the run position but can either be in neutral or have the clutch pulled in to start the bike.
Since you said the bike starts and runs I'll assume we are down to the neutral sensing switch/wiring or the possibility the relay is bad.
Be methodical and test each circuit(switch, wires, end-to-end etc.) Whether they are open or closed "normally" is just based on how they were designed. In other words they could be opposite of what you'd think but still be fine. Make sure the switches go from open to closed if at all possible.
BTW, I'm hoping 5 hours was just a wild asses guess on their part because otherwise it means things are really buried and this is going to be difficult.
Good luck and let us know how it works out.
Really? I'm not doubting you so much as not seeing that in this diagram.The neutral light is part of the safety circuit. If the LED is bad, it will keep the circuit open to the neutral safety switch, and can be overridden by the clutch switch. Jump the wire for the light at the connector to ground. If the LED lights you know it's definitely a bad switch, if not, replace the LED.
Looking at the attached diagram and write up I'm leaning heavily towards the neutral switch not thinking it is in neutral. Your description of what you have to do to start the bike is "b" on the diagram. If "a" were satisfied you could start the bike... I start it all the time with the kickstand down and clutch disengaged.Really? I'm not doubting you so much as not seeing that in this diagram.Unless I'm missing something...and I very well could be.
The thing to remember when looking at this manual is that it covers 2 different bikes. Ours is the 2nd one (XVS13CA(C)), so in this case, it would be the diagram on 8-31.I'd personally check all the fuses first if you haven't already. Not that it's likely going to be the issue but it's worth a shot.
Here is the manual for the bike taken from another post on this forum:
http://www.mediafire.com/?1n2h5yjk1nlygwq
On page 8-29 is the diagram break out with item 35 being the actual neutral indicator light which is an LED.
The multifunction meter is item 36 which I'm assuming is the speedo/highbeam/etc panel.
I'd personally pull the cover off the top of the bike display and check the LED for voltages while the bike is in neutral then trace back from there.
I feel the same way. My riding season is just about over so this is all I have left... If I could ride then of course I'd be like "sucks to be you dude..." Just kidding. Always nice to see the final resolution since sooner or later all of us will encounter the common issues that any given vehicle has.No no no we are all waiting patiently for you to go troubleshoot and tells us what the problem is we are not gonna wait til the weekend. Jk jk
It's actually under lighting circuit. It shows a path from the neutral light to the neutral safety switch, the other circuits come from the clutch and sidestand, so the clutch can close the circuit to ground when disengaged. I still think it may be a faulty switch, that's why he needs to check the voltage and not just continuity. It might be an open circuit before the switch, and the only thing I can see is the LED. That's why I mentioned he should run a jumper and see if the light is actually burned out.Really? I'm not doubting you so much as not seeing that in this diagram.Unless I'm missing something...and I very well could be.
NP.I retract..I was trying to look at the schematics on the computer at work, and with all the crap IT loads on (it's health care) it's hard to navigate efficiently, but you're right...my bad.
Bad switch...
